1993 Suburban knocking noise
Hi I have a 1993 suburban and After I
start it I hear a tapping or knocking noise coming from the up front passenger side of the truck by the glove compartment. It stays on for about a minute or so after I start it and after I turn the car off. I was wondering if anyone knew what this could be? I thougt it might have something to do with the AC. Thanks for your time!!! -Johnj< ="><!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> |
I have the same problem. Its a little flapper valve located on the far right bottom corner of the heater box. Its some type of fresh air or recirculation flapper. If you will notice you can move your controls from different settings and it will make it flap doing that. I have put up with it for about 2 years and wish I knew the fix. Let me know if you do.</P><edited><editID>Shayne7s</editID><editDate>38695.5911226852</editDate></edited> |
