1995 Tahoe ignition switch issues
1995 Tahoe ignition switch issues My daughter called and had trouble turning the key in the ignition, After about 1/2 hour of jiggling the key, trying to tirn the steering wheel back and forth & adjust the tilt up and down the key finally turned. The ignition switch was replaced about 4 years ago. I'm sure it's in my thread someplace. The switch was replaced with an OEM GM switch. She is using the most often used key - the original OEM. We haven't compared keys yet. We might have one that is not as worn if that is possibly the problem Any thoughts or ideas? Thanks |
lock cylinder?
Have you tried the new keys that came w/ the new lock cylinder?
