1997 Suburban Heater conrol issue
Good afternoon all. I recently purchased a 1997 Suburban. The truck is in excellent shape and I love it. I realized today that the heater blows only in the floor mode. When I switch it to face, or defrost I can hear the air change but only a little flow come out of the vents. The rear heater works just fine. When I make the move it sound like the air is "re-directed" and the floor air flow is diminished, but virtually nothing out of the top vents, where do I start. I ordered a manual for it today, so hopefully that will help.
I also should mention the A/C light does not come on either.
You can reach under the steering column, by the pedals, and there is a lever you can push that will re-set the blower motor. But most likely you need to replace the blower motor. I just ghetto-rigged mine for now. I secured the lever in place so it wouldn't fall back & only blow from the bottom vents. Has been just fine for a few months now!
1997 chevy 1500 recirculation stuck on and ac wont turn on only blows hot..
Ac work when hard wired but still blows hot and the recirculate light stays on everything els works it can move abit from one vent to another and fan speed works fine.. what would cause my ac to not turn on and for it to blow hot even when it’s on the cold setting? And why is reciric on constantly?? Please help
