1999 Suburban windshield wiper and cruise control problems
The windshield wipers and cruise control on my 1999 Suburban work very intermittently-more often than not they don't work. My hunch is that it's the multi-function switch (turn signal). Any ideas on how to diagnose this problem?
Thanks |
Did you ever get a reply? I am having the same problem.
Originally Posted by tnelliott3
(Post 223106)
Thanks |
I have a 98 Suburban as well that does not run well so I think I will try that multi-function lever in my 99 to see if that takes care of the problem. I have found new switches on line as low as $60.
Try your brake switch first. Easy and cheap to fix. Fixed my CC . Could be that they are not related......
I'm having the same problem, but mine is only the wipers. When they are off, they continue to run for a couple of cycles, then stop. In all the delay settings, sometimes it will delay and sometimes it will go at low speed. Thanks for any help.
| All times are GMT -5. The time now is 4:25 AM. |
