2000 suburban Lt rear center brake hose, input needed!
#11
-Seth
#12
Brake line tubing has a special coating on it that's supposed to resist corrosion. The name of the coating escapes me presently. The brake line tubing is double flared also and requires special tooling.
#13
some steel lines are zinc rust coated some have nothing at all. the ones with no coating will surface rust within 3 months. I spray steel lines with rubberized rocker guard to protect them.
copper lines will split when double flaring and will not withstand the high pressures the system generates.
copper-nickel is perfectly acceptable to use and is the easiest to bend and will not rust.
red891500
October 24th, 2006 9:20 PM
