-   Tahoe & Suburban (https://chevroletforum.com/forum/tahoe-suburban-25/)
-   -   2001 Suburban 2500 auto ride shocks (https://chevroletforum.com/forum/tahoe-suburban-25/2001-suburban-2500-auto-ride-shocks-72816/)
denm613 May 21, 2015 12:02 PM
My Suburban has auto ride shocks, and if I replace them with the same shocks it will be expensive, anyone have a suggestion.
Thanks Dennis
Scotiapilot May 22, 2015 12:47 PM
IMO not worth it. Replace with regular shocks.
denm613 May 23, 2015 6:47 AM
If I replace them with regular shocks, the light on the dash will stay on, how do you get it to go off? Thanks Dennis
Scotiapilot May 24, 2015 12:14 AM
Pull the fuse for the autoride system. Its in the underhood fuse box
denm613 Oct 9, 2015 8:38 AM
auto ride
I've looked in the fuse box under the hood and on the side of the dash, I'm not seeing anything marked as auto ride. What is the fuse marked as?
mulmur1 Oct 9, 2015 11:06 AM
The fuse is located under the hood and marked as RTD Autoride (Real Time Damping) image below
https://cimg9.ibsrv.net/gimg/chevrol...76f542f6f8.jpg
denm613 Oct 10, 2015 6:37 AM
Thanks for your help, I'll be pulling that fuse today. I'd taken it to a shop and was quoted a price of around $1700 and I think that's a bit much for four shocks.
Dennis
denm613 Oct 10, 2015 8:16 AM
I've just pulled the RTD fuse, but the message center still says---Service Ride Control, what can I do to get the computer to think there is no Auto Ride option?
Thanks Dennis
mulmur1 Oct 10, 2015 10:18 PM
To remove the error message, you can either have the bcm reprogrammed or add a resistor to fool the system into thinking that the system is still in place. The reprogram is the best solution, but more expensive. It essentially would delete the auto ride system, so that the computer does not think it is installed.
Ian Reilly Nov 10, 2016 4:10 PM
Disconnect the Negative battery terminal, remove the fuse, reconnect battery.
Just learned that on another site looking to fix the same issue.
Thanks Dennis
