2001 Suburban stuff not working when it came back from body shop
My Suburban had hail damage to the hood and roof, it also needed the rocker panels replaced which means the headliner had to come down and all the doors had to come off, when it came back the door lock button on the drivers door that controls all the doors didn't work, ok maybe someone didn't plug a connector in, but the 2 outlets next to the lighter don't work now and the accessory outlet on the rear of the console doesn't work, I haven't checked the accessory outlet in the way back yet. The mirror wire was missing it's cover and it would have to be pulled out farther for it to fit because it seems to be trapped under the headliner, sun visor brackets have a gap under them I can stick my little finger in, drivers side kick panel not properly installed, it interferes with the operation of the hood release on the passenger door the rubber boot for the electric harness was never installed, and the trim around the rear wheel openings was installed too low and doesn't fit the body profile, there's a gap of about 3/8". What I'm thinking is there a connector under the headliner that was not plugged in, or could it all be related to the drivers door?
Last edited by denm613; August 30th, 2017 at 11:06 AM. Reason: additional information
Several months later a tire had a slow leak, when my son went to get the jack, there was no jack or anything that went with it, now I've taken the drivers side sun visor down to have it recovered and there is a hole in the headliner panel with nothing in it, what goes in that hole. We bought this vehicle new and it's never been left anywhere so this was a very bad experience.
slow leak in the tire is unrelated to a hail damage repair to the roof.
Any good body shop will address any problem from improper installation or a missed connector etc. You should address this promptly.
jack missing
The hail damage was part of the reason the car was in the body shop--- the slow leak in the tire was the reason we needed the jack--- and the point was after everything else the was wrong with the Suburban now I find out they took my jack too!
