2001 Tahoe 5.3L 4X4 A/C cuts out
Original 2001 Tahoe owner 220,000 mileshttp://www.tahoeforum.com/images/smilies/whymewhyme.gif- I start the Tahoe and the air runs nice and cold, sit around for a while and the compressor cuts out warm air blowing...... I drove on Rt 80 for 200 miles no problem, ride in town stop and go A/C compressor cuts out.....warm air blowing. Last night I changed the clutch fan. Started it today and left the hood open, nice and cold for hours, close the hood, after a while A/C compressor cuts out. Leave the hood open and checked it later and the compressor was back on blowing nice and cold. NO I CANNOT DRIVE WITH THE HOOD OPEN UNLESS I CUT A HOLE IN IT...LOL Any ideas??????????????
Is the fan clutch engaging when the hood is down and vehicle is stopped?
Check the A/C pressures when the compressor shuts off. If the fan isn't running and pulling air thru the condenser, the high side pressure will increase and trip the high pressure switch. |
I will let it idle with the hood down and when I feel the duct air go humid and start to warm I will open the hood and see if the fan is locked. I will report back.
I let it warm up until the A/C cut out. Opened the hood and the NEW fan clutch I installed 2 days ago is not locked. I guess it means that it is hot enough to make something open in the A/C circuit but not hot enough to make the fan clutch lock. It is 66 degrees right now outside in NJ. |
I know a guy who has A/C gauges, I will take it to him and let him see if anything looks suspicious. Thanks for the suggestions. |
The pressures will tell you if the freon charge is correct. Too much or too little can cause the high or low pressure switches to open.
And if the pressure increases or decreases to the point that the compressor shuts down, then you'll know. What's the water temp. when fully warmed-up? |
Originally Posted by 73shark
(Post 343162)
NO A/C when Tahoe not moving hot under the hood.....
(Post 343162)
And if the pressure increases or decreases to the point that the compressor shuts down, then you'll know. What's the water temp. when fully warmed-up? I hope this helps someone else because there wasn't a low pressure issue, so why check it when you have a problem when the engine compartment gets hot and points to a high pressure issue..........the Tahoe is a pleasure to drive once again! |
Thanks for reporting back on your solution. Glad you got it fixed.
(Post 343411)
Might try your Chevy parts dept. I'll try to look in my parts catalog.
Forgot that this was the Tahoe forum. My parts catalogs are Corvette. |
