2001 Tahoe lights work sporatically
My 2001 tahoe headlights work for a few hours then stop. All fuses and bulbs are good. I removed the dash switch, the lights work even without the switch attached. The lights react the same, by morning they turn on then after a few hours of use same repitition. <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- edit note -->
same problem with my 99 Chevy 1500. They work for a few hours and then turn off OR don't come on at night when I start the truck. Checked relay, fuses, ambient sensor, relays and switch. All other lights work fine... just no low or high beam headlights.
exact same problem as "In the dark" except i do have high beam. This is what i use do drive around with. I checked the connections at the stearing column everything appears intact what next?
mukherjee_mk
August 28th, 2012 11:18 PM
LeeA
April 13th, 2012 4:28 AM
kleesman
October 28th, 2008 8:48 AM
