2003 Auxillary Outlets not working
I have a 2003 suburban and all power outlets aren't working. I read the other posts to try and solve my problem but didn't find anything. This is what happened... I was using an small air compressor plugged into the cargo area auxiliary port to pump up a bike tire. The outlet stopped working but I was done. I later found out the other 2 (front auxiliary and lighter) stopped working too. I checked the fuse on all three with a meter and all 3 fuses were good. I replaced the fuses anyway and all 3 outlets still aren't working. Would the pump make all three outlets go bad at the same time, without blowing fuses, and while only plugged into the rear cargo outlet? Any ideas would be helpful.
Welcome to the forum.
Find the common tie point for the three outlets and then trace it back to where its source of 12 volts is. It could be a bad connection. |
