-   Tahoe & Suburban (https://chevroletforum.com/forum/tahoe-suburban-25/)
-   -   2003 Chevy Tahoe Reduced Engine Power (https://chevroletforum.com/forum/tahoe-suburban-25/2003-chevy-tahoe-reduced-engine-power-107071/)
Truckman77 Oct 1, 2021 12:23 PM
Had engine replaced in my 2003 Chevy Tahoe 5.3 Flex. It runs perfect. But if i cut on my ac, hold window but down too long or hold door lock button too long i get message reduced engine power. I get error code P1518. (I have a brand new throttle body and a brand new throttle actuator It doesn’t have any trouble starting) I then gotta use my scanner to reset the code. Any suggestions? Thanks
repairman54 Oct 2, 2021 8:08 AM
Here's a start. Weak battery is a prime suspect, just because it cranks and starts doesn't mean it's good.
P1518 CHEVROLET code possible causes
  • Dead or weak battery
  • Faulty Throttle Actuator Control (TAC) module
  • Throttle Actuator Control (TAC) module harness is open or shorted
  • Throttle Actuator Control (TAC) module circuit poor electrical connection
  • Check Throttle Actuator Control (TAC) module connector for water
Truckman77 Oct 3, 2021 10:46 AM
Repairman54 you were exactly right. Got a brand new battery and everything is good. Thanks man
Rednucleus Oct 3, 2021 1:43 PM
Window button was a good clue the battery was tired.
Truckman77 Oct 4, 2021 10:13 AM
I thought it was fixed but its back to doing the same thing. Might be a ground wire
