2005 Suburban LT A/C issues
Hello all. New member here. I have a 2005 Suburban LT with the digital dual climate zone and auto setting. Just had the compressor replaced Monday and it still is having some issues.
When running at highway speeds, the ac blows cold as ice (45-50 degrees). When you slow down or come to a stop, it goes up to about 80 degrees. I have an automotive thermometer in the main vent next to the radio to tell where it’s sitting. I know this week in Florida is super hot and that the system would struggle some but why the extreme fluctuation? Bottom line is, I’m missing something and need some help.
Also, last year I replaced the electric fans while chasing an overheating issue which ended up being the oil pump.
When running at highway speeds, the ac blows cold as ice (45-50 degrees). When you slow down or come to a stop, it goes up to about 80 degrees. I know this week in Florida is super hot and that the system would struggle some but why the extreme fluctuation? Bottom line is, I’m missing something and need some help.
2. Are your electric fans behind the radiator BOTH working full time???? And are they both pulling air from front rearwards towards the engine?
3. Are you sure that the compressor was the correct one for dual air?
4. When you come to a stop and the AC performance is bad, open the hood and use a flashlight to determine whether the AC compressor drive plate (the center disc) is actually turning, and not just the outer AC clutch pulley.
5. I'm in Arizona, and you folks in Florida have no idea what heat really is....
Sorry for the late response guys. So I had the compressor replaced due to poor performance. The A/C guy I took it to said that when he took the old compressor off it was stock and had metal in the orifice tube and that it was starting to come apart.
As I stated before, I replaced the radiator fans last year and literally the same day the A/C decided it wanted to quit working properly. Could it be something to do with the new fans? I have the original ones still sitting in my garage and have considered putting them back in to see if there is a difference.
And if at all possible, can we leave the condescension out of replies. Not being a jerk but I am a novice after all and trying to find answers so I can get my girl operating right again.
Thanks
Thanks
Update
So, if you’ll forgive my lack of speedy updates on here. Lol. The ac issue ended up being the radiator fans. I put the stock ones back in and the system started working perfectly! Thanks for all the suggestions and advice.
Gonna start another thread for an additional issue that just popped up this past week.
repairman54 (October 4th, 2022)
