2005 Tahoe signal light
Sorry if this has been answered before, I could not find the thread.
How do you change the bulb?
Thank you in advance.
Edit: This is the front signal.
Not sure if you mean front or rear. On my 05 burb...
Frt: when you open the hood and are looking down at the light there are 2 levers ( metal ) that you sort of twist out towards the front of the truck. Then pull up and the come out. Are long and L shaped when they are out and they slip through holes in the light housing and anchor it. This gets your headlight out which allows access to the park/signal housing. That is held in by a clip that you should see once you have the headlight out. Look at it close, you will be able to figure them out. Not much to it.
Rear: When you open the rear hatch there are 2 phillips screws holding the tail light assemblies in. Take them out and the assembly comes right out and you can access the bulbs.
fishingpro77
HHR
August 4th, 2016 12:44 AM
VAJim
July 3rd, 2012 2:51 PM
bambam1414
April 28th, 2012 1:53 PM
RomanGuzi
October 2nd, 2011 11:40 AM
