-   Tahoe & Suburban (https://chevroletforum.com/forum/tahoe-suburban-25/)
-   -   2007 Liftgate Problem (https://chevroletforum.com/forum/tahoe-suburban-25/2007-liftgate-problem-42463/)
jcurtis69 May 13, 2011 8:51 AM
I recently had my rear liftgate stop working. Apparently there is no obvious way to open the liftgate once the latch assy. stops working. I would grab the exterior handle and nothing would happen. I wouldn't hear the latch as I normally would. The glass hatch worked fine though.
I was told that I would have to attempt to remove the interior panel, which is near impossible to do with the liftgate closed, this commonly damages the panel. Crazy considering the panel is about $495.00! The latch assy. cost between $95.00-$165.00. I was lucky and found one on ebay for $60.00.
The new latch assy. has a long plastic strap to run to the top of the panel to facilitate easy access and release the latch. As I inspected the interior panel I noticed a small (1/8") circle molded into the panel near the bottom just right of the latch (center). After I drilled this out with a 1/8 " bit I used a 6" long wire, clothes hanger strength, and inserted it attempting to push the release up in the direction the strap on the new one would be pulled.
After about 1 minute of trying this I succeeded. The hatch opened. The replacement of the latch took about 10 minutes. The new latch solved the problem!
If you run in to this problem let me know and I'll post pictures...
The dealer acted as if they didn't know how to do this....
ousig2408 May 13, 2011 9:19 AM
wow I have not heard of this but you really should post pictures because this will be very handy for anyone else with issues.
the power liftgate is handy at times but there are many times I wish I had a regular one so when I am in the garage I can lift it and slowly let it rest on the garage door. instead now I have to unload in the driveway then pull the truck in...
gamecock May 13, 2011 12:14 PM
awesome tip.
Spicoli May 13, 2011 3:11 PM
The problem could still exist without the power liftgate. My 2007 doesn't have a power liftgate but it still han an electric release latch on the outside handle.
ousig2408 May 13, 2011 4:14 PM
you are correct - still I don't like having the let the power liftgate open to the top or it will come back down if it hits something. I dont think many garages are tall enough to let it open inside the garage.
Spicoli May 13, 2011 5:21 PM
I have the same problem with the lack of room. But without the power liftgate I can open it slowly and stop it before it smashes into the garage door. :)
Chevrolet Customer Service May 18, 2011 3:24 PM
Spicoli,
Are you having any direct issues with your lift gate other than the lack of room? If so, please let me know!
Thank you!
Elizabeth, Chevrolet Customer Assistance
Spicoli May 19, 2011 12:24 PM
Originally Posted by Chevrolet Customer Service (Post 181774)
Spicoli,
Thank you!
Thank you for asking but I don't have a problem with my lift gate at all. I was saying that due to my lift gate not being a powered lift gate I can control how fast and how far up it goes. Thanks, Jeff.
Chevrolet Customer Service May 19, 2011 2:46 PM
That’s good to hear. If you ever have any problems, feel free to contact us!
Thank you,
Elizabeth, Chevrolet Customer Service
jcurtis69 May 20, 2011 10:34 AM
2007 tahoe liftgate
Well, I replaced the latch. Now the problem is back. Intermittently the liftgate wont open. or it will start to release then not open. almost as if the exterior handle isn't working. The other day the liftgate opened on its own when i unlocked the truck. It has done it twice now.... I'm baffled... It sound like an electronic problem somewhere, not a hardware issue.
