2007 Power Source
My wife has an IPod in her truck and it uses a cigarette lighter power outlet for power(constant power). I would like to hard wire it into, preferably a power source that is controlled by the ignition.
Would the ant. wire on the stereo be the best bet? If so, how do I remove the stereo? If not is there a certain fuse in the fuse block (by the driver's door) that has only accessory power? If there is not an easy option for accessory power, I will just choose a hot wire. Thanks. Kevin |
RE: 2007 Power Source
I found a wire in the fuse block.
before u go hard wiring something in you should make sure that the item u r hardwiring is 12 volts and not a different volt. the easiest way to hardwire is to get a metra CLA wgich is a the female side of a cigarette plug with a positive and negative wire comin out of the opposite end. also it is not a good idea to put it on a constant wire, it should be connected to an accessory so that when u shut the truck off the unit shuts off as well...
I agree, I am an electrician. I work mostly on large back-up generators for buildings.
Thanks for the input though. |
ORIGINAL: addkev I found a wire in the fuse block. Which one???? I spent a lot of time yesterday looking for one with no luck!!!! The Owner's Manual gives descriptive codes (so does the panel cover) - what is the code for that particular fuse?? |
I spliced into a wire that is right in front of the fuse panel. It is a pink wire with a purple stripe. It has 12v while the ignition is on. I stripped the insulation and soldered directly to it. There is an excellent ground right there on the fire wall.
Kevin |
ORIGINAL: addkev I spliced into a wire that is right in front of the fuse panel. It is a pink wire with a purple stripe. It has 12v while the ignition is on. I stripped the insulation and soldered directly to it. There is an excellent ground right there on the fire wall. Kevin Does anyone have a wiring schematic for the 07 Tahoe?? Before I go tapping into circuits, I'd like to know where the wire goes.... |
After doing a search, I decided to post here instead of starting a new thread.
I too am looking for a retained accessory power source for a TV tuner. As it is now it's wired up to ignition power which means I can't sit in the truck with it off and watch TV. I was wondering if it's possible to tap into the power on harness C-1 of the head-unit to get this power? Any thoughts? Has anyone been successful finding a good retained accessory power source? |
ORIGINAL: TMW597 After doing a search, I decided to post here instead of starting a new thread. I too am looking for a retained accessory power source for a TV tuner. As it is now it's wired up to ignition power which means I can't sit in the truck with it off and watch TV. I was wondering if it's possible to tap into the power on harness C-1 of the head-unit to get this power? Any thoughts? Has anyone been successful finding a good retained accessory power source? |
Thanks for the suggestion, but I need to find retained accessory power. Every 12v power port in the vehicle is "always on" power, front, center console, and cargo area.
| All times are GMT -5. The time now is 5:00 AM. |
