2007 Suburban:Glass opens when opening/closing talegate in both power and manual mode
2007 Suburban LT 4WD
No replies so I am going to try to explain better (or maybe I'm the only one). When opening/closing the tailgate (either manually or with the power option) the latch for the tailgate glass will release at about the half way point of being opened/closed. I don't know why this happens and I have not found anything online about it. Has anyone else had this issue? Thanks. |
My guess is damaged wiring. Check the wiring/conduit where it exits the tailgate and goes into the body. If you have exposed/damaged wires, as the tailgate opens or closed the wires make contact as if the button was pressed.
