4wd working or not?
Just bought a 08 suburban Ltz w 50k miles.
I got stuck in some pretty wet grass. I had it in 2 wheel drive so I switch it into four-wheel-drive. I put the transmission in neutral before I shifted into four hi. The light was blinking on for high and then turn to solid. I put the transmission back into first gear and then step on the gas but only the rear tires spun I couldn't believe it I was stuck in a flat wet grassy area. I tried shifting into four low using the same process but no matter what I did I could not get in the front tires to engage. I could even hear the tc engaging and disengaging when going in and out if 4wd. I did turn off the trac control when I was in 4 hi but made no diff I assume the front tire should be spinning right? Felt like a lamo Aaron |
I also had my wife roll slowly while I was lying on the ground watching the front driveline. It turns in 4wd and doesn't in 2wd which is what I would expect. Adds to the confusion for me of why the front wheels don't spin in 4wd.
Jan Rosenberg
When you engage 4 WD the front axles have to be engaged which should happen automatically. Sound like a problem with the front axle / diff. Actuator system.
Originally Posted by jrosen8129@aol.com
(Post 298684)
Wish it was more old school mechanical. Hope it's not turning my good deal into a bad one lol. Thanks for your thoughts. Anyone else? Aaron |
Originally Posted by 08burban
(Post 298687)
I have a bad feeling you're right. Some how power is not being transferred :(
You're right Aaron, anytime you shift out of 2WD, both front wheels should be turning. Hard to say exactly what it is, but, you might put it up on a chassis rack, engage the 4WD, and see if you see any shafts turning. That should help localize the problem.
issue
You don't need Neutral to engage 4 high.
and I agree, it sounds like an issue with the front diff/hubs engaging. |
Here Are the results of my testing with all wheels off the ground
In 2wd /first gear - rear wheels turning - front driveshaft turning - front wheels not turning In 4wd hi /first gear - rear wheels turning - front driveshaft turning - front wheels turning - I can stop both front wheels at the same time with a friend. This doesn't seem right. I should only be able to stop one right? I can hear the encoder/actuator motor engaging and I hear a clunking noise going into 4wd. Could the motor still be bad? |
Front axles
If you can stop the front wheels but the front driveshaft still turns then it is definately a problem with the front axle / diff. Actuator system
Its your hubs, they need to be cleaned properly and you can do it.
