gmarcos74 |
November 22nd, 2010 6:33 PM |
96 burb 2wd negative camber problem
Hi, I have a 96 suburban 2wd, I just finished installing a 4" Spindle kit from rough country in the front ( it originally had 2" coil spacers intalled) and a 4.5" block set in the back. When I finished the install I noticed allot of negative camber on my front wheels is this due to worn out upper ball joints ( I replaced both lower joints) or the shock being too short? If it helps when I drive around it feels like there is no suspension travel at all!!! Please help!!
