97 suburban stuttering and stalling, need help.
I have a 97 Chevy suburban c1500 5.7L 2wd. Last year I replaced some badly worn parts.
Fuel Filter Fuel sending unit Crankshaft Position sensor Coolant Temp sender Ignition Coil Ignition Control Module Dis. cap and rotor Last month I had codes ran on it and it came up with a p0131 fault. Last week it started stuttering and stalling really bad. I would be in traffic trying to go forward and it would just stutter badly. This past weekend I replaced the spark plugs, plugs wires, and the O2 sensor. I took it around the block and its still doing the same things. I am not too sure what else it could be. If anyone has any thoughts please let me know. If I can't fix it, I will be selling it. Thank you in advance. |
Distributor?
Yes the distributor cap and rotor.
