Last edit by: IB Advertising
Browse all: Steering and Suspension
- Chevrolet Silverado 1999-2006 GMT800 How to Replace Steering Box
98 suburban steering issues?!
I have a 1998 chevy suburban 4x4 7.3L 8600gvw K2500. My power steering pump shaft snapped. I replaced it.Drove great until it snapped again. Replaced it. It snapped again!! I took it to the mechanic, told him my story, he replaced it and told me my steering gear wasn't cycling the fluid and replace it asap.Drove it half a mile home, replaced the steering gear, bled the system, now it acts like it don't have power steering, but the brakes work fine, where they had went out before. I took the belt off and the shaft is not broke.Please someone give me something to check or do. Troy in Washington.
Do yo have over size tires on this truck . like 285 or bigger. could be your problem why the shaft keeps snapping.
Did the service guy fill the gear box with fluid before putting it back on the truck ? check your power steering fluid level also. I would hate to think that your power steering pump went out just after you replaced the steering box. you should always fill the steering box before with fluid before putting back on the truck. it's also good to turn the gears on the bench to get the pump well lubricated. then fill up the power steering pump and bleed. This should have all been done when they replaced the steering box. you should not have to bleed the pump this should have been done already. did you put the new steering box in or the service guy? in any case the above applies
Painteddaddy
September 28th, 2013 11:10 AM
2000suburbanjeff
August 31st, 2013 1:28 PM
bobbygrady
August 14th, 2013 8:57 AM
cyberrkatz
January 31st, 2011 8:54 AM
