Air Bag Light
I could use some help please, My 2005 Chevy Suburban 1500 ls 4wd air bag light came on the other day. At the same time my rear entertainment TV screen will not work(no power to it at all.) I have already look at the wiring under the front seats and they look O.K. If anyone has any suggestions I would greatly appreciate it.
Brfd |
Welcome to the forum...
I'd suggest to check all fuses both in the IP side panel and under the hood... |
Originally Posted by in2pro
(Post 283988)
I'd suggest to check all fuses both in the IP side panel and under the hood... I checked fuses, all are O.k any other sugguestions Thank nYou |
The airbag light could be due to one of the front airbag sensors going bad. I had this happen to me a couple of years ago. Replaced it and all was good again. As far as your other issue, it might not be related to your airbag light but something else entirely. Hope this helps.
Originally Posted by brfd777
(Post 283986)
Brfd I had vehicle scaned by a friend and the only codes were c0035 and co455, doesd anyone know if these codes could be causing the airbag light to come on. Thank you |
(Post 284321)
Air bag light
(Post 283986)
Brfd Thank you all for your help |
(Post 284562)
I think I will get a sensor and replace the front ones one at a time to see if that's were my problem lies, if that does not work I will take it to the dealer.
Thank you all for your help I got lucky, the first sensor I change was the bad one. The light went out and everything is O.K. I want to thank everyone for the help! |
Thank you for following up on your fix :) its what makes the forums work:cool:
