-   Tahoe & Suburban (https://chevroletforum.com/forum/tahoe-suburban-25/)
-   -   Back Up Camera Problems (https://chevroletforum.com/forum/tahoe-suburban-25/back-up-camera-problems-57223/)
Joe In NY Mar 21, 2013 8:19 PM
So I cleaned my throttle body 2 days ago and unhooked my battery as an attempt to help the ECU relearn the throttle-body before finding the proper procedure. But now that the battery is hooked back up my back up cam wont turn on when i go to reverse! it works if i do the window lock over ride but if i have to turn it off when im done...
any idea what happened???
in2pro Mar 21, 2013 9:14 PM
Welcome to the forum...
I am checking the info I have and not seeing a lot :(
Is there any information on the screen when you shift into reverse?
Joe In NY Mar 21, 2013 10:45 PM
the screen still displays the regular radio and i can change it and use it like its in park or drive. i might have to pull the head unit and check the over-ride.
73shark Mar 22, 2013 2:43 PM
I'm not familiar w/ the "lock lock override". What's that?
mulmur1 Mar 22, 2013 9:22 PM
Joe,
Which navigation / video in motion / bypass product are you using in your truck? It sounds like you have it setup to control the rear camera, where the power wire to the rear camera runs through the bypass unit, rather than the factory method? It is possible that unit is the problem. You may want to try and see if there is a firmware update for the unit and flashing the chip may solve your problem. A call to the company's support may help solve this issue.
Good luck with your repair.
Joe In NY Mar 22, 2013 10:50 PM
oops, sorry about the "lock lock" its only the window lock button, press 4 times to switch to rear camera, the power isn't run through the override as the camera has to be turned on by Reverse and shuts off after 30sec. To unlock Nav I just hit the "Talk" button 4 times. But lately the Nav has been locking up real bad when we use the override, so have to program it ahead of time now :(
I can't remember who makes as I only saw it once. We bought this suburban by paying our friends the difference of our old one and this one back in Feb 2009 when it had 50k on it. He installed the override as soon as he bought it in 2007. It worked flawless until now...
I'm going to be pulling the head unit tomorrow to have a look. But I don't know why unhooking the battery would cause this... We still can watch movies up front and everything else the over ride provides...
I'll get some pics.
73shark Mar 23, 2013 12:27 AM
Sounds like it may be a Lockpick by Coastal Tech.
Joe In NY Mar 23, 2013 7:53 AM
yep. thats it! I have a lockpick. dont know which one tho... but I have a feeling that it is the Head Unit that is at fault, not the lock pick, as the head unit still controls the camera...
I'm going to mess with it today so.
Joe In NY Mar 23, 2013 9:11 AM
5 Attachment(s)
Crap! My Lock Pick is at fault! I wonder if it got a power surge from when i hooked my batter back??? IDK. But we are driving to Florida next Friday and we want it working! I have to call lock pick up and find out what has happened.
now all 6 dip switches are ON. It has worked great till now :( I would pull it out but the donkey who put it in glued it! so i guess it stays.
Never mind. it was just wedged really good, LockPick is old, has no other switches or plugs, cant update it either :(
Joe In NY Mar 23, 2013 9:12 AM
1 Attachment(s)
here it is working with restrictions and everything. as you can see i'm holding the Lock Pick Wire harness
