-   Tahoe & Suburban (https://chevroletforum.com/forum/tahoe-suburban-25/)
-   -   Belt replacement (https://chevroletforum.com/forum/tahoe-suburban-25/belt-replacement-49210/)
WanderingOak Mar 6, 2012 4:54 PM
Belt replacement
I've replaced the serpentine belt before on a 1988 S-10 with a 4.3 V6, but the belt on this 98 Tahoe with a 5.7 V8 has me stumped. On the 4.3, all I had to do was put a breaker bar on the tensioner, rotate it CCW, and the belt would loosen and come right off. On this truck, however, when I try to do that, all I wind up doing is loosening the bolt holding the tensioner on. The Haynes manual for this truck tells me to do exactly what I just did.
Is there a special procedure for changing the belt on this engine?
cleveland63b Mar 7, 2012 9:29 PM
pull the other way on the tensioner
EinST Mar 7, 2012 10:03 PM
There should be a square hole on the tensioner arm. Insert a 3/8" wrench or breaker bar into the hole and then turn it CCW.
cleveland63b Mar 8, 2012 1:31 PM
ah i had 5.3 on the mind...thats the 15mm you turn clockwise my bad
