Brake Controller Battery Hookup
I thought I read in the manual I have to connect a wire under the dash to enable the power to the factory brake controller?
If I have the factory brake controller in my 09 tahoe, do I still have to do that? We put new axles on my boat trailer this winter, I haven't wired the trailer yet (just wanted to get the axles on, wiring + lights this spring) when its NOT 20 degrees outside... Once I have the trailer all wired up, 7 pin, do I just connect it, or do I have to pop the hood and hook up that wire? seems stupid GM wouldn't just connect that wire, what lawyer came up w/that? thanks! |
Originally Posted by SabrToothSqrl
(Post 126142)
I've got the trailer brake controller but haven't read about it yet. I did notice a wire w/ a ring terminal on it taped to the underhood harness next to the fuse box. I did wonder about what it was for.
I didn't know they offered a factory controller. I would think that if it came with one it would be wired. I installed one on my 06 silverado and had to install the factory harness that was provided with the tow package, when I installed one in my 07 Escalade the wiring was there and it needed to be connected to the power supply under the hood.
I will look when I get to it this summer i guess... I still need to wire the brakes on the trailer as well... thanks.
Originally Posted by 73shark
(Post 126419)
power
which is for charging the battery on the brake system, correct? which is required when towing a trailer w/electric brakes... so why do they leave the stupid thing unpluged?
One less thing to short out...
