Brakes squealing
I am having a prob with my brakes squealing. I have changed my brakes and turned my rotors. I have swapped out the pads twice already bc i thought the pads were defective. I'm using ceramic pads. It squeals when i'm driving btw 0 - 35 mph. If i'm braking the squealing gets louder or if i'm turning it gets a lil loud. I always work on my own stuff and I hate to keep wasting time and money on the wrong thing. I'm starting to think it might be the calipers. Any thoughts or ideas on what this might be?
Originally Posted by baby luv
(Post 186012)
Oh, its a 2002 Tahoe
(Post 186015)
I did use the anti-squeal on the backside, but i didn't know about the anti sieze. What does that do?
(Post 186017)
It was tacky before I put them on and I've changed them out 3 times in the last 3 months. Everytime i changed them, it immediately started squealing. The first time I didn't do the anti-squeal, but the last 2 times i did and i even turned the rotors both times the last 2 times i changed the brake pads. I will try the anti-sieze to see if that works though.
(Post 186022)
make sure the wear indicator on the pad is not bent and contacting the rotor surface prematurely....
Have you checked the wheel bearings? Why do you think it is the brakes? Which brake do you think it is that squeals? Try putting it up on a jack stand and spin the tire by hand and see if you hear anything. Try non-ceramic pads.
| All times are GMT -5. The time now is 3:47 AM. |
