clunking 07 sub
clunking 07 sub
Dealer tech could not replicate a thunk that sounds like is coming from the rear end on my 07 burban. It's most noticeable when driving next to solid objects...parked cars, concrete wall, etc. When I drive over a fold in the concrete, I'm getting a thunk/clunk in the rear.
Suspension? Loose shock? Rear tailgate is about to fall off?
Make sure the spare tire is firmly mounted, make sure you don't have a loose jack in the jack stowage area or any other items for that matter... do check the shocks they can slip off the rubber grommet or it can deteriorate...
Think like the clunk.. are you heavy and solid or light and tinny?
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> thatguywill,
Agreed, did the tech drive with you, like "tech2" suggested?
Louis
GM Customer Service
Louis
GM Customer Service
Not yet. It's a bit of a haul to get to the dealership from where I'm at. There was one right down the road, but, well, we know how most of those ended up.
Clunk is heavy and solid. At this point I suspect shock or rear sway bar (if it has one?).
dzonen
February 15th, 2007 11:13 AM
