Code p0410 on 01 tahoe
Newly member and first post. I took my 01' tahoe to the dealership to get a diagnostic because the check engine light came on.The print out they gave read "P0410 - AIR INDUCTION SYSTEM FAILURE. I did some re-search online it mention's a vaccum hose leak, a hose is leaking air, or a faulty air pump. I hope someone can help me.
Symptoms are as followed: 1. The car turns off when doing a sharp turn or a U-turn. 2. The voltage meter goes to 9 when not stepping on the accelerator ( when stuck in traffic on the freeway) 3. Going thru railroad tracks or dumps not stepping on the accelerator it turns off. I hope this helps in trouble shooting. Thank you |
Welcome to the forum...
sounds like you might need to check the battery cables and ground cables the code could be symptom and not a cause... make sure all battery connections are tight at all points, the starter, the engine, alternator. check for any corrosion... |
Checked
My battery has proper voltage, auto zone checked the alternator and starter which was good. Any other suggestions?
have a 2001 GMC Yukon 5.3l and have the p0410 code coming up. changed gas cap, purge solenoid, spark plugs, air pump, air pump relay, charchoal canister and still getting code. I did noticed that the air pump goes off while driving at times, which I know should not. I live in CA which is dry and checked the pump and no water or moisture what so ever. Any ideas?
