-   Tahoe & Suburban (https://chevroletforum.com/forum/tahoe-suburban-25/)
-   -   Disable sensor on low beams (https://chevroletforum.com/forum/tahoe-suburban-25/disable-sensor-low-beams-3893/)
LTZ_HOE Nov 26, 2006 6:36 PM
Any idea how to disable the sensor that turns on the lowbeams to a 07 tahoe? Any information would help greatly. :)
jlenkows Nov 26, 2006 6:45 PM
RE: Disable sensor on low beams
My most radical thought would be to simply unplug it at the sensor (or just remove the sensor completely.
LTZ_HOE Nov 26, 2006 6:51 PM
Where would the sensor be located?
jlenkows Nov 26, 2006 6:54 PM
It's that little greyish dome in the center of the dash where the dash meets the windshield.
LTZ_HOE Nov 26, 2006 7:08 PM
Any idea on how to disable that without ripping up my dash board? Do you know if there is a fuse I can pull instead?
sjenkinzz Nov 26, 2006 7:46 PM
Why do you want to disable?
LTZ_HOE Nov 26, 2006 8:03 PM
Because I have a set of HIDs that I don't want to burn out. I want to be able to turn on my headlights manually.
jlenkows Nov 26, 2006 9:10 PM
According to the Tahoe manual (page 209)...
Turn the control to this position to turn
off the automatic headlamps and daytime
running lamps (DRL). Turning the headlamp
control to the off position again will turn the
automatic headlamps or DRL back on.
Now last time I checked, the off switch is a momentary switch...
Here's the link to the manual: www.mygmlink.com/pdf/go2content/manual/US/en/chevrolet/2007tahoe.pdf
xclusive Nov 26, 2006 11:06 PM
the problem with doin this is like u said it momentary switch so u have to do this everytime u get into the truck, which is a pain... are you sure the ball in the center of the dash is the sensor. i thought it might have been the built in compass...
ORIGINAL: jlenkows
xclusive Nov 26, 2006 11:08 PM
get the top of the dash apart is easy...u need to pop 6 clips and it will come right off...i would use a plastic panel popper to get it off though this way there is less chance of you scratching the dash...
ORIGINAL: LTZ_HOE
