DRL Module location
Anybody know where the location of the DRL module is on a 96 Tahoe 2Dr. It's a small printed circuit board with 8 connectors.
DRL Module location found
I finally found the module location. It was a gray plastic box wrapped with the large wire harness. Once I removed the tape around the harness I found the box and there is an opening on the top with wires on the bottom. Once you open the top, the module can be pulled out with pliers and the new one went right in. DRL now working again.
RE: DRL Module location found
Hey Bud can you expain a little more detail of where this grey box is .I have the same problem you did Thanks Paul
The module box was located on the left side of steering column (facing steering wheel) and it was wrapped in electrical tape to the thick harness of wires. The module was completely taped over when I found it. Look for a large bump in the wiring harness.
Thanks Bud I'll look
Where is location on 2002 Suburban? Fuse is ok. Relay is ok. My bulb is ok. Must be module?
1 Attachment(s)
Give this a read and see if it helps...
drl relay on a 2004 express 2500 location as it's not listed on fuse cover and isn't inside
Thanks |
