DTC Code
Wondering if anyone could help me out with a code my 2002 is throwing.....not sure if it is a coincidence...but got new exhaust put on about a week ago.....the check engine light came on last night.
P0106 - MAP/BARO CKT Range/Perf Thanks! |
RE: DTC Code
Didn't find much here: http://www.obd-codes.com/trouble_codes/
Might try this one: http://www.justanswer.com/chevy.asp?r=gacar Did you check the connections to the MAP sensor? Don't know where it is but maybe it got jostled during the exhaust install. |
RE: DTC Code
I haven't had a chance to get underneath yet....I may tomorrow if it isn't 15 degrees out, like it was today! :)
RE: DTC Code
I believe the MAP (Manifold Absolute Pressure) sensor is connected to or mounted on the intake system.
