have a 2007 suburban sometime it will not start the first turn of the tho?
What will cause this problem need help .
Originally Posted by Maurice Carter
(Post 429774)
For best OBD bluetooth scanners click here When you turn the key, does it crank? If it does, it is not likely that the battery or starter are a problem. Best thing to do is scan for codes, as this might tell alot. For instance, you might have a bad crankshaft sensor. This will cause crank-but-no-start situation. Hope that will help. |
You say it will not start the first turn. Does it start after that and just crank for a few extra seconds? If so then you have a bad check valve in the fuel pump assembly.
2007 suburban will start the first try???
(Post 429774)
Do a fuel pressure check at first start up and see what the pressure is.
I have-2007-suburban-sometime-will-not start the first turn .
Hey Guys I just put my 2007 suburban in for service for the problem listed above , check back later with the results 😔
