Heated Steering Wheel
The Heated Steering Wheel is only availible for the Yukon Denali and Escalade... If I order one from GMPartsDirect for the Denali.. Would it fit on my Tahoe?
RE: Heated Steering Wheel
For some reason I thought there was a guy in the forum whos tahoe actually had a heating steering wheel. But I am not 100% sure of that, anyways Im curious as well.
The wheel does not come with air bag attached. At least I don't think so. You will have to uninstall and reinstall the entire wheel then atttach the bag.
The heated steering wheel will not work as a plug and play device.
The system takes power from a fuse in the under-hood fuse block #48 which Tahoe's are not pre-wired for.
You will need to add a connector at possition #48 and install a 15Amp fuse then run the power lead up the the steering column and pin it in the center possition of steering Wheel module controller (SWMC) connecter , you will also need to install an in-line 7.5Amp fuse before the steering wheel.
The two wire leads listed below will probably already be present in most Tahoes:
Then you need to run a signal reference wire (if not present) from the GN/WH lead out of the SWMC to the position C9 of the body Control Module (BCM).
Lastly you will need to run a ground lead (if not already present from the final empty socket in the SWMC.
Once it is all connected if it does not work then a VCI code will need to be obtained from GM to allow this function via the BCM, this can be very tricky to get.
Frank3
February 23rd, 2015 6:25 PM
