HELP!!! multi probloms with Burb..
2003 suburban... onstar blinking on and off.. cruise control light on cluster not working.. 4x4 light on cluster not working.. left hand blinker light on cluster not working.. drivers side seat up and down switch working backwards.. both front heated seats will only come on one at a time and only for a few seconds.. dealer tells me no active recalls.. the 4wheel drive, cruise control and blinkers all work fine.. so I don't realy know were to start to look for probloms.. also this suburban only has on battery.. is that normal on some models or has someone removed a battery?.. :confused:
All Suburbans have only one battery. Diesel pickups get two.
It looks like you have a lot of electrical issues going on with your truck. You're not going to find the solutions by peppering each individual problem all over the forum. I'm sure most, if not all of the problems, are related. It would appear to me that you need to take the truck in to a professional to troubleshoot. Either a dealer, or a qualified mechanic. |
thank you!.. finely someone who might have a clue on what there talking about.. but I did buy a new 2004 burb with a gas engine and it had two battery's in it.. I figured it was for the a/v system or the removable snow plow.. anyway thanks for the info.. yes I think it is a wiring problem.. I just needed a step by step diagram on were and how to start for each problem.. I guess I will just buy a gm diagnostic cd..
Good idea
Great idea, it is nice to see others who try to work on their vehicles "if possible", I am no mechanic but save a great deal of money and learn a great deal about my vehicles when I work on them. I usually know where & when I am over my head and take it to my mechanic. Best of luck.
Two batteries?
My '96 K2500 GMC Suburban with a 5.7 Vortec 350 has two batteries. The one on the passenger side runs the starter when required to. The drivers side battery has a positive cable coming over from the other battery to charge it. Its purpose, apparently, is to power the computer crap on the fender well.
1 Attachment(s)
Originally Posted by bobpur
(Post 289615)
The battery doesn't power anything when the engine is running - that's the job of the alternator. The battery is simply being used as a reservoir/buffer. The main reason there's room/provision for a second battery is when the truck has a diesel engine. PPV Tahoes also come with a second battery to power all the extra lights and equipment. That being said, my 08 has two batteries...;) Attachment 10576 |
there are a couple of bulletins on the wiring under the drivers seat shorting out on the bar running across the bottom of the seat rails, it can cause the seat module to short and can cause com problems. did you scan for codes? as in U codes? Also check the grounds from engine to the body.
