HVAC blows cold on warm setting
2005 Chevy Suburban
All of a sudden my suburban is blowing cold air when my temp is turned up to the highest setting in the 80s and blowing hot air when turned to the 60s. It's like the Temps are flip flopped. Was driving home when it happened then my water gage shot down to the lowest temp of 160. Idk what this could be. There is coolant in my car. Only thing that happened right before this was my car wouldn't start because the black cable was loose. Fixed that and now these other issues are coming about. Haven't got the black cable tightened all the way yet. Just made it home. Could that possibly be the issue? A bad connection with the battery?
I'm surprised how common off an issue this seems to be. In your air conditioning system there are two small "radiators". One is always hot and the other is cold. What is called a "blend door" is the plastic piece that diverts air through one or the other, and the "blend door actuator" is the tiny motor that is likely your failure point that controls the blend door based on your temperature input.
This video shows the principle of how it works. At the beginning of this video he shows a test where you remove the actuator and move the blend door my hand to see if the blend door is OK. If the blend door is intact, order another actuator and install that one. Just make sure to line up the door with the new actuator.
Awesome!! Thank you. I'll look into getting that done today, and see if that corrects the issue. My water temp gauge is now working which is weird. The air is also now blowing correctly. Cold when on cold temp and hot when on hot temp. I'll get this changed out anyways just to be on the safe side.
Samantha - I wouldn't just jump into a repair right now except your battery cable thing. I've experienced blend door actuator issue on our own 2005 Yukon, and shutting the engine off, then restarting it, re-set it. So possibly the battery cable thing is all the fix you need, try that first for a few days.
This is NOT a refrigerant level issue, don't let anyone touch that !!!
The following 3 users liked this post by Cusser:
kirk88
July 21st, 2011 8:49 PM
