Indoor light problem
Hey all, new poster here. I recently bought a 2001 Chevy Suburban. At the time I bought it everything worked as it should. I now have an issue that I would like to see if I can get help with.
When I open the door the courtesy (dome lights) do not come on. There are lights on the outside mirrors that do come on but no lights come on in the interior. I have a bypass button by the headlight switch that I pushed and it worked the first couple of time but now it does not work either. I have also noticed that the ABS light and traction control light stay on sometimes and other times they light up but then go off. Everything else on the truck seems to work fine. I have checked both interior light fuses in the cab and also the CTBY fuse under the hood and nothing is blown. I don't know if this is a known problem that I can fix or if there is a short in the wiring. Any help would be appreciated.
Thanks,
Randall
Thanks,
Randall
beckya99
July 12th, 2011 12:29 PM
Deteoni
March 28th, 2009 1:39 PM
