Installing OEM 3rd Row DVD
In 2008/09 GM offerred 3rd row stand alone OEM Panasonic drop down DVD screen for the people in the 3rd row to watch instead of watching the 2nd row DVD.
I have a 2007 Suburban with OEM Nav Radio/DVD with 2nd row OEM DVD and was hoping someone has added a 3rd row DVD that can help me with parts and installation instructions Is there an extension wiring hardness to extend video signal from 2nd row DVD to 3rd row DVD? You can buy the Panasonic OEM DVD drop down screen on Ebay for $100 |
Should be able to get the connector from the dealer and wire it to the 2nd row dvd. One thing that you'll have not do is hook up the audio to the 3rd row. If you do, the 2 infared signals will cancel each other out and the 3rd row passengers will not get audio through there headphones
The parts guy at my dealership could find nothing about a separate extending harness, he feels the harness is one piece that extends to the 3rd row DVD when the truck is build and theres no add on.
Any idea how one would confirm this? Also how do you figure out which of the wires in the harness are for IR? I notice the 3rd row OEM Panasonic DVD is different in that it has no IR lights on it so maybe Panasonic supplied two versions of their flip down OEM DVD screen to GM. |
There is no official add-on unit. But it can be done by simply adding the components. Upon further investigation of your vehicle, the
rear screen would have to be wired directly into the rear of the radio. And yes you are right, there are 2 different screens...one with and one without IR tansmitters To accomplish this, you'll need a spool of sheilded speaker lead to go from the rear of the vehicle to the radio. (example http://www.fadfusion.com/selection.p...er=20027800083 ) You'll need 5 wires to go the same distance You need to get 4 pins for the rear of the radio, Terminal/Tray: 15359541/4 (parts guys should know what this means) And finally, the connector for the video, and you'll need 8 pins for the connector. Part numbers and pic below Video Display - Rear (DNU) http://gsi.xw.gm.com/image_en_us/gif...11/1711011.gif Connector Part Information
Thank you for all the help, this is excellent.:)
I didn't realize it meant pulling a wire all the way along the headline and then pulling the stereo out. I thought I could just fish a wire from the 2nd row DVD to the 3rd row DVD. I'm guessing the video signal wouldn't be strong enough to power both monitors right? A video amp would be required probably. Might be easier to do headrest monitors. |
You could try running it off of the first moniter, but like you say, the signal may not be strong enough. Pulling the radio and running wires to it is not as hard as you might think it is.
Keep us posted when you decide which way you're going to go |
Originally Posted by Brewboy
(Post 86094)
I didn't realize it meant pulling a wire all the way along the headline and then pulling the stereo out. I thought I could just fish a wire from the 2nd row DVD to the 3rd row DVD. I'm guessing the video signal wouldn't be strong enough to power both monitors right? A video amp would be required probably. Might be easier to do headrest monitors. Brewboy --- how did it turn out? Did you install the 3rd row oem display? Any pix of DIY's? |
shawnvw, help!
Hey shawnvw, thanks for all your help! I'm doing something similar...not quite and this thread got me 75% there (I think). What I'm trying to do is make a wire harness from the front nav/dvd unit to the 2nd row dvd screen. My truck (2007 Tahoe) didn't come with either but I bought both from ebay...the nav unit is installed and working. The piece I need is the (I believe) c3 connector for the rear of the nav unit. The other parts you listed should get the rest done:
* OEM: 15490628 * Service: 89047355 * Description: 10-Way F Kaizen 0.64 Series (BK)
* Terminal/Tray: SAITS-A03T-M064/14 * Core/Insulation Crimp: P/P * Release Tool/Test Probe: J-38125-215/J-35616-64B (L-BU) Am I correct in this assumption? Do you know what the part number is for the c3 connector? My dvd screen DOES have the IR built in so I'm assuming I will need to run more than 5 wires. The information I have about the back of the nav unit is as follows: 14-Pin Connector C1: Pin Wire Color Circuit No. Function 1 RD/WH 340 Battery Positive Voltage 2 TN 201 Left Front Speaker Output (+) (UQ3) TN 511 Left Front Low Level Audio Signal (+) (UQA/UQS) 3 L-GN 200 Right Front Speaker Output (+) (UQ3) L-GN/WH 512 Right Front Low Level Audio Signal (+) (UQA/UQS) 4 PK 5149 Voice Recognition Audio Signal (UE1) 5 PK/BK 5152 Low Reference (UE1) 6 WH 7066 Entertainment Remote Enable Signal 7 YE 6817 LED Backlight Dimming Control 8 BK 2550 Ground 9 GY 118 Left Front Speaker Output (-) (UQ3) D-GN 1947 Left Front Low Level Audio Signal (-) (UQA/UQS) 10 D-GN 117 Right Front Speaker Output (-) (UQ3) OG/BK 1546 Front Low Level Audio Signal (-) (UQA/UQS) 11 Bare 2011 Drain Wire (UQA/UQS) 12 -- -- Not Used 13 D-GN 5060 Low Speed GMLAN Serial Data 14 -- -- Not Used 16-Pin Connector C2: Pin Wire Color Circuit No. Function 1 BN/WH 367 Remote Radio Left Audio Signal (U2K) 2 D-GN/WH 368 Remote Radio Right Audio Signal (U2K) 3 Bare 2099 Drain Wire (UQA/UQS/UK6) 4 L-GN 7396 DVD Video Signal 2 (+) (DNU) 5 BN 199 Left Rear Speaker Output (+) (UQ3) BN/WH 599 Left Rear Low Level Audio Signal (+) (UQA/UQS) 6 D-BU 46 Right Rear Speaker Output (+) (UQ3) D-BU 546 Right Rear Low Level Audio Signal (+) (UQA/UQS) 7 D-BU 658 Cellular Telephone Voice Signal (UE1) 8 OG 6978 Amplifier Control (UQA Except Y91) 9 TN/WH 372 Remote Radio Audio Output (-) (U2K) 10 GY 388 Remote Radio Right Audio Signal (U2K) 11 Bare 1573 Drain Wire (U2K) 12 WH 7394 DVD Video Signal 2 (-) (DNU) 13 YE 116 Left Rear Speaker Output (-) (UQ3) BN 1999 Left Rear Low Level Audio Signal (-) (UQA/UQS) 14 L-BU 115 Right Rear Speaker Output (-) (UQ3) TN 1946 Right Rear Low Level Audio Signal (-) (UQA/UQS) 15 L-BU/BK 659 Low Reference (UE1) 16 D-GN/WH 7395 Video Mode 2 Signal (DNU) 16-Pin Connector C3: Pin Wire Color Circuit No. Function 1 YE 2059 Auxiliary Audio Left Signal 2 WH 2058 Auxiliary Audio Right Signal 3 L-BU 5826 Left DVD Audio Signal (+) 4 WH 5828 Right DVD Audio Signal (+) 5 OG/BK 5831 Remote Infra Red Signal (+) 6 PK/BK 5844 Video Bright Control 7 D-GN 6975 DVD Video Signal (+) 8 PU 2056 Auxiliary Video High Signal 9 Bare 5345 Drain Wire 10 L-GN/BK 5845 Video Module Signal 11 PU 6979 DVD Audio Common 12 Bare 6980 DVD Audio Shield 13 TN/WH 5830 Remote Infra Red Signal (-) 14 Bare 6976 DVD Video Drain Wire 15 WH/BK 5335 DVD Video Signal (-) 16 Bare 5346 Video Drain Wire 16-Pin Connector C4: Pin Wire Color Circuit No. Function 1 -- -- Not Used 2 -- -- Not Used 3 D-BU 6760 Center Channel Low Level Audio Signal (UQS) 4 WH 6763 Subwoofer Low Level Audio Signal (UQS) 5 D-GN/WH 817 Vehicle Speed Signal (UVC) 6 PK 6972 Camera Signal #2 + (UVC) 7 L-BU 6973 Camera Signal #2 (UVC) 8 PU 5837 Amplifier Audio Prompt Signal (+) (UQS) 9 -- -- Not Used 10 -- -- Not Used 11 OG 6761 Center Channel Low Level Audio Signal (-) (UQS) 12 PK 6762 Subwoofer Low Level Audio (-) (UQS) 13 Bare 6759 Drain Wire (UQS) 14 -- -- Not Used 15 Bare 5838 Drain Wire (UQS) 16 GY 5836 Amplifier Audio Prompt Signal (-) (UQS) Do you know which wires from c3 (and/or other listed above) need to go to which pins on the dvd screen connector (OEM: 15490628 Service: 89047355)? Thanks for all your help! |
I decided to go with Headrest monitors instead of the 3rd row install. The deciding factor for me was the mounting of the DVD player into the factory brackets and purchasing all the right parts. I didn't realize how many parts were involved in mounting.
For the same price I bought a high quality set of Headrest monitors with built in DVD players. This way the kids don't fight over who gets to pick the movie, they can each pick their own and its much quieter for me! |
Originally Posted by DaddyMacCadillac
(Post 148066)
| All times are GMT -5. The time now is 3:27 AM. |
