Intake manifold gasket- what else
So i finally found the source of the burnt coolant smell that's been going on for the last year on my 99 suburban. 80,000 mi. 5.7 L, K1500. I have to replace the notoriously bad intake manifold gasket. Since I'm taking all the spaghetti off, what else should I replace while I'm at it. Thanks.
This is my reply copy and pasted from your other thread:
I'm going through this myself on both my 98 K1500 Silverado and my 96 GMC Yukon both with the Vortec 5.7L engine.
Make sure you use the Fel-Pro MS98000T gaskets. They use an upgraded material that is less likely to fail. Also, completely flush the cooling system before you do the intake manifold gaskets and put in conventional coolant instead of GM Dex-cool. You have to make sure you flush the system completely because Dex-cool and conventional coolant can not be mixed.
Do NOT use any "extended life" antifreeze. Even if it's green colored if it's extended life it's rebadged Dex-cool. You can either buy pre-mixed 50/50 or buy 100% coolant and mix it with distilled water. No, you can't use normal bottled water or tap water. You must use distilled.
The Dex-cool is what kills these engines, in addition to the plastic intake gaskets. Between the upgraded metal Fel-Pro gaskets and the conventional coolant you should never have to do the work again.
Also consider replacing the water pump, upper and lower radiator hoses, thermostat, radiator cap, and coolant resorvoir tank. If you're willing to spend the money do the radiator as well. After doing all of this work I would recommend doing another coolant flush with fresh conventional coolant maybe a month after everything just to make sure no Dex-cool is left. I know the cost adds up and it's overkill but you want the Dex-cool gone. Also be sure if you take your truck to a shop or you get your oil change done by one of those quick-lube places (please don't, but I understand if you are in a hurry) that they don't top up with "extended life" green or other color Dex-cool...
I know this is a lot of parts, time, and money but these are powerful and reliable engines other than the cooling system problems, and you will get many more years of service out of your Vortec if you do this.
Also be sure to do an oil change right after you do the work because while your intake manifold gasket might be leaking externally if might also be leaking a little bit into the oil which even if you can't see or smell it can still permanently damage the engine.
This information applies to all vehicles using the Vortec 350 (5.7L), Vortec 305 (5.0L), and Vortec 4.3L V6...
dj lpm
February 13th, 2012 1:04 AM
gulfcoastjoe
May 4th, 2008 12:38 PM
vfilby
December 28th, 2007 12:53 PM
