OEM wire colors
Does anyone know how I could get a hold of the OEM wire colors for a 1997 Tahoe. Im trying to get my alarm installed.
RE: OEM wire colors
12volts http://www.directechs.com/images/clear.gif red http://www.directechs.com/images/clear.gif + http://www.directechs.com/images/clear.gif ignition harness http://www.directechs.com/images/clear.gif http://www.directechs.com/images/clear.gif Starter yellow or purple + ignition harness Ignition pink + ignition harness Power Lock lt. blue either door boot http://www.directechs.com/directwire/images/note.gif Power Unlock white either door boot http://www.directechs.com/directwire/images/note.gif Lock Motor gray drivers door boot Unlock Motor tan drivers door boot Disarm Defeat tan passengers door boot Parking Lights+ brown headlight switch Parking Lights- Hazards Turn Signal(L) Turn Signal(R) Door Trigger purple - headlight switch Dome Supervision white - headlight switch Trunk/Hatch Pin tied in with doors Hood Pin Trunk/Hatch Release black or blk/wht low in the drivers kick http://www.directechs.com/directwire/images/note.gif Power Sliding Door Factory Alarm Arm Factory Alarm Disarm Disarm No Unlock Tachometer white AC ECM http://www.directechs.com/directwire/images/note.gif Horn Trigger black - at column Memory Seat 1 Memory Seat 2 Memory Seat 3 CHEVROLET, TAHOE, 1997, Power Lock The 4 door versions are positive trigger, and the 2 door versions are 5-wire. CHEVROLET, TAHOE, 1997, Trunk/Hatch Release Positive trigger on models with rear lift window, and 5 wire on models with cargo doors. CHEVROLET, TAHOE, 1997, Tachometer Diesel wait to start wire is dk. blue (-) located at the instrument cluster. ECM is located on drivers side inner fender. Tach wire found in a black plug marked white |
RE: OEM wire colors
Hey thanks for the feedback. For the links that were provided, is there some type of password that i need for the directechs.com site? like theres a couple of links on the reply that have no info, its just a link... is there impt information needed in those links? thanks.
