Oil pressure woes, 06 Sub
So since the Holiday season, my 06 Suburban has had oil pressure issues. The truck has 246K miles on the odometer. The symptoms are as follows. Low pressure at the gauge. 20 PSI or less. Also a clicking from the engine as if there is a bad lifer/rocker. SO I researched the issue and found that GM had trouble with the o-ring on the oil pump pick up tube. I replaced that. No change in symptoms. I then replaced the oil pump with a new Melling unit. Again, still low oil pressure and the clicking remains. At this point I am at a loss. Not sure if the sender is bad and my oil pressure is fine?? But, beings I still hear the clicking I am concerned. What else can I check out?
Brandon |
You can try a mechanical oil pressure gauge to see if the reading is actually low. What oil are you using? You can also try a thicker oil like 20W50 to see if that helps any.
Originally Posted by oldchevy
(Post 351551)
