-   Tahoe & Suburban (https://chevroletforum.com/forum/tahoe-suburban-25/)
-   -   P0101 and P0300 codes Runs really bad (https://chevroletforum.com/forum/tahoe-suburban-25/p0101-p0300-codes-runs-really-bad-71583/)
UM Rebel Mar 18, 2015 3:22 PM
Hi this is my first post on this forum. I have a problem with my 2004 Suburban I hope someone can help with. It runs really bad, no power, clatters and backfires will hardly go over 45. CEL is on and sometime flashing. Autozone read codes P0101 - Mass Air Flow (MAF) Circuit Range/Performance Problem
P0300 - Random misfire
Changed MAF with my Corvette. Corvette still runs fine (no codes). Suburban still runs bad. Checked cats temp front (300 degrees) , back (500 degrees). Checked fuel pressure at 45psi . Where do I go from here? What do y'all think is going on? Thanks for any help and advice.
UM Rebel Apr 17, 2015 10:58 AM
If anyone is interested. This turned out to be catalytic converters. Confirmed by removing before cat O2 sensors and taking for a ride. With sensors out it ran good and very loud. Replaced cats. Runs like new again.
in2pro Apr 17, 2015 3:13 PM
Thanks for follow up on your post and what the fix was! its what makes forums work :)
FWIW, my 07 Tahoe, when I check the catalytic converters temps they are more around 1100°-1200° under normal driving conditions...
brian90vette Oct 13, 2019 9:39 AM
Cat
I also had the P101 and P300. I cleaned the mass air flow sensor and it did nothing. I took out the K&N air filter that was in therefor 12 years and put stock back it just to rule K&N out, still did nothing. Shelled out 100 for new MAF, nothing. I hooked up a pressure gauge upstream of the cat with an adapter that screws into the o2 sensor port and found restriction on the driver side. Bought a new cat online for 130 took it to a shop, the guy says P101, P300, its not the CAT but if you want to pay us and keep throwing money at parts, we will put it in. 5 minutes later, shop guy comes in and says the CAT was 95% blocked. Replaced the Cat runs great no codes.
73shark Oct 13, 2019 7:09 PM
Brian: Welcome to the forum. Thanks for the info.
James The Plumber Jun 12, 2020 2:02 AM
Same problem
My 2003 Silverado 4.3 was loud and was told to change manifold gasket which I did and now I have codes 0101 and 0300 . Truck is quite now and when idle sounds okay but as soon as try to take off it’s barely moving and will have small backfire sounds . I was going to change 02 sensor but now I’m thinking it’s probably the cat . Is there anyway to tell without removing and driving without 02 sensor ??
