Potential Grounding Issue?
2007 Suburban LTZ.
I've had a series of peculiar electrical issues of late;
1) backup camera is "black",
2) clock on radio was off but radio worked fine, then it started working but wont keep time until you push that area of the screen it will update time
3) rear compressor for air ride only works if you jump relay under hood - changed controller under car, new shocks, new compressor - works fine manually but no auto adjust (I started another thread on this last year and it still doesn't work)
4) complete bank 1 ignition coils stopped working - traced issue to no ground at connector between coil packs. Although I suspected a bad ground on the level control module, I haven't check that yet. Wondering if I have a bad ground bock or broken ground wire somewhere. Cleaned and verified upper engine bay ground when fixing coil packs, but may be another location that I am unaware of...
Yes, sorry - should have added that.....the bulbs are fine, no power at the socket and the ground seems fine.
All other lights in the rear work except the tag lights.
And the reverse lights work on the trailer plug (verified with 7-way tester).
Thanks so much for your help!
I will check that out - didn't think the trailer plug and rear truck would be fed off of different relay - god point. I will dig into that today perhaps - thanks again for the pointer......
I really do think that I have a series of "related" issues with all this stuff seeming to go wrong - I cannot imagine multiple electrical failures on various sub systems - makes me think of a bad loom junction or something. I had a siilar issue in my 06 Jetta where the factory extended a wire inside a loom (not straight run) and the connection rotted out. Turned out to be a pretty common failure point - was hoping to find a similar "trend' on the truck and fix multiple issues at once ;-) Will check relay and fuse.....
if they have a common issue...tracing the one problem will locate the common fault. pull up a power distribution diagram and see what's shared.
radio is body wiring
air compressor is chassis wiring
coils are engine harness
Where do you want to start?
maxstead
March 11th, 2023 4:30 PM
Guitar
July 7th, 2016 8:33 PM
mccallseth
March 10th, 2008 1:28 PM
