-   Tahoe & Suburban (https://chevroletforum.com/forum/tahoe-suburban-25/)
-   -   Radio cutting out! (https://chevroletforum.com/forum/tahoe-suburban-25/radio-cutting-out-2330/)
timdogg1313 Aug 21, 2006 11:49 PM
Radio cutting out!
My radio in 1997 4 door 4x4 tahoe is cutting out and won't come back on until you turn the key off and then turn it back on again. the radio does not lose power, just no sound after about 30 seconds to a minute of play. I tried changing the factory unit out with an aftermarket radio and it still does the same thing. Thanks for the help
ZX1100F1 Aug 22, 2006 12:01 PM
RE: Radio cutting out!
In your case there is an obvious problem with the power source to the radio. Could be as simple as replacing a fuse that is faulty but not quite as bad as most that burn out.
timdogg1313 Aug 22, 2006 11:51 PM
I've got it somewhat figured out. I think a wire is shorting out on the right side of the vehicle. I balanced the radio all the way to the left and it hasn't cut out again. Thanks for the help.
timdogg1313
