Radio Turns Off When Ignition Is On
2005 Suburban - Radio Turns Off When Ignition Is On
I have a 2005 chevy suburban with an aftermarket sony head unit. It used to work fine for two years. Now, the radio only works if the ignition is in the accessory position. Once you start the truck, I hear a click and the radio turns off. Please help!!!!
Welcome to the forum...
did you do the install or was it done for you? The relay that powers the radio may be bad or a connection that allows power when the ignition is on has broken... find the relay that is clicking and start there with re-seating its connections.. And if you have not already check all fuses
