Service 4 WD
Service 4 WD came on my message board and was wondering why?
there is a fault in the 4wd system. post make, model, year, engine and the code set in the tranfercase control module...full function scan tool required...code reader cannot access chassis codes.
A few more questions. Do you have a knob on the dash to control the 4WD and if so does it have a setting called “ Auto “. Lastly, how many miles since you changed the fluid in the transfer case.
SD |
Make, Model & Year
Originally Posted by tech2
(Post 351295)
Just had my transmission rebuilt about a month and half ago
Yes there is knobs on the left side of the dash to control the 4 W D. and yes there is one that says Auto
Originally Posted by Silveradogirl88
(Post 351385)
The transmission is separate from the transfer case. The transfer case fluid needs to be changed every 50,000 miles.
The fact it’s an auto transfer case makes this even more important because there are clutches inside the case that rely on the fluid being in good condition. |
Service 4 W D
Originally Posted by Suburban Dude
(Post 351436)
(Post 351436)
The fact it’s an auto transfer case makes this even more important because there are clutches inside the case that rely on the fluid being in good condition. https://cimg9.ibsrv.net/gimg/chevrol...084176773a.jpg https://cimg0.ibsrv.net/gimg/chevrol...04a18fe1b7.jpg https://cimg5.ibsrv.net/gimg/chevrol...7a6498df31.jpg |
