shift lever stuck in park
2002 avalanche 1500 4x4 z71. Replaced key lock cylinder and case. Restored pass lock. Now shift lever stuck in park.
What can I do to free it? |
Are you applying the brake? The vehicle won't shift out of park if the brake peddle is not depressed, there is a lock pin that prevents the shift from happening if the brake is not pushed down, you may have disconnected the power to this pin.
Yes I push hard. I also checked the solenoid. Seems to be ok. Can a ignition switch affect it?
Yes it could if the pin is in a bind and unable to retract
I really appreciate your thoughts. This all started with replacing the ignition lock cylinder. After I reset passlock is when I found shifter stuck in park. I also forgot to mention that I replaced the brake switch to no avail. What pin are you referring to? I am going to check the shift interlock solenoid again. I didn't pull it yesterday just disconnected it thinking it should release. But got to thinking if plunger is stuck, that would not affect it. So I am diving in again!
try wiggling/turning the steering wheel while trying to get it out of Park.
I have tried that and I jacked the rear wheels up and rotated the wheels in case it was the transmission pawl. No luck.
When I say "pin" I am referring to the shift interlock. In all likelihood that is what is causing your problem, its either not getting power to disengage it or its wedge/stuck in. The brake peddle being depressed is what actives the retraction of the "pin" to allow the shift lever to move.
2 Attachment(s)
See if these help any, and no, the links in the document are not clickable as they reside on my PC....
Thanks for the schematics and troubleshooting guide In2pro. I thought that you were talking about the interlock shift but wanted to be sure. I am taking a break until next week when it warms up a bit. I will get back to you with the results.
