-   Tahoe & Suburban (https://chevroletforum.com/forum/tahoe-suburban-25/)
-   -   Suburban hesitation (https://chevroletforum.com/forum/tahoe-suburban-25/suburban-hesitation-51229/)
highroad June 17th, 2012 11:03 AM
Suburban hesitation
My 2004 Suburban hesitates at acceleration. Sometimes from a stop and sometimes when trying to get out of somebody's way. Seems to have become worse and now happens more frequently. Any ideas? Thanks
in2pro June 17th, 2012 11:09 AM
First thing that comes to my mind is the Throttle Position Sensor...
But it might be worth checking the fuel pressure as it could a fuel demand/supply issue....
kevinkpk June 17th, 2012 2:17 PM
Whats the idle rpm?
highroad June 17th, 2012 4:30 PM
Hi, Thank you both for responding. The idle rpm is just between 5 and 600. Again, it seems to happen more often now to the point where--I'm typically a leadfoot--I am afraid to accelerate too fast because it causes this problem. I cannot get out of my own way! Thanks again.
kevinkpk June 17th, 2012 4:55 PM
That is low, I'd suggest pulling the vacuum hose off the regulator to see if you have gas in it, if so, replace it.
elaf55 September 23rd, 2012 8:04 AM
Hello, I currently have a 2011 Suburban with 70k and it also has a hesitation going from a stop light it feels like its clogged up or something not sure but I do have to step on the gas to go faster ? any advice thanks
in2pro September 23rd, 2012 10:09 AM
Welcome to the forum...
and 11 with 70k...I would try a couple of bottles of Techron in a take of gas, if you see some improvement, having the injectors cleaned professional may be needed.
Also check/replace the air filter..
elaf55 September 24th, 2012 6:52 AM
Can you provide me with the best cleaner product ? And do i place it when the tank is full or nearly empty?
in2pro September 24th, 2012 8:16 AM
I have had good results with Techron and 3M products..though there are many on the market. BG products seem to be the rage however I have not used them... Add to a partial tank and fill up. If it improves have the injectors professionally cleaned.
73shark September 26th, 2012 3:40 PM
I agree w/ Techron.
Is BG available to us regular consumers?
