Tahoe no rear air only heat
Guys,
I have a 2005 Tahoe Z71, automatic rear air and heat. last winter I had no heat. I took it apart and as a quick fix I moved the heat/air door to heat for the winter. I got back into it this weekend and with intentions of fixing it since I had more time. I swapped the air/heat actuator with the upper /lower vent actuator and the problem followed the actuator. Great, problem fixed, get a new actuator. Problem is is the descriptions dont make sense to me. the one that I think it is is a Dorman 604-100. Problem with that it is a four pin connector, the one that failed is a 2 pin then a space then a 3 pin. Does anyone know the correct part number for a rear heat/air actuator? Dorman or GM part number? Thanks, Scott |
Welcome to the forum.
Might try gmpartsdirect or your friendly Chevy parts man. |
1 Attachment(s)
Rock Auto appears to have quite the listing of parts and part numbers see if any of these fit the bill....
