-   Tahoe & Suburban (https://chevroletforum.com/forum/tahoe-suburban-25/)
-   -   TPMS sensor matching on new rims and tires (https://chevroletforum.com/forum/tahoe-suburban-25/tpms-sensor-matching-new-rims-tires-97653/)
boley Oct 10, 2019 10:41 AM
I have a question related to installing new tires and rims on my 2011 Suburban LTZ.. These new wheels will be have 17 inch rims for offroad and winter use, and will have all new TPMS sensors. I will also be keeping the factory 20 inch wheels for summer use, and they will keep the original TPMS sensors.
The question: If appropriate TPMS sensors are purchased (315 mhz OEM style), does one only need to do the normal relearn process (TPMS Sensor Matching per the manual) or does something extensive need to be done in the Suburban's computer?
I have a TPMS relearn tool and experience relearning tire position after a wheel rotation. I just don't want to get into a whole mess of needing to register new sensors in the vehicle's computer. Based upon what I have read, it seems like the Suburban's relearn process will recognize any appropriate TPMS sensor, but I cannot fine a crystal clear answer. So here I am double checking. Thanks.
tech2 Oct 10, 2019 11:12 AM
performing the normal relearn procedure is all that is needed.
adibonen Nov 16, 2019 4:13 PM
Auto learning in 07 sub
I just replaced an old TPMS sensor in my 07 Suburban.
From the "Resetting the TPMS Identification Codes" section of the owner manual: "Any time you rotate your vehicle’s tires or replace one or more of the TPMS sensors, the identification codes will need to be matched to the new tire/wheel position."
That was my clue that the system will learn new TPMS sensors automatically.
Indeed, relearning the sensors was a breeze. Breaking the tire seal to get to the sensor and later inflating the tire took a bit more effort. Overall the job took about 40 minutes.
