-   Tahoe & Suburban (https://chevroletforum.com/forum/tahoe-suburban-25/)
-   -   Trouble Codes, Check Engine Light (https://chevroletforum.com/forum/tahoe-suburban-25/trouble-codes-check-engine-light-47104/)
chazwel Dec 12, 2011 1:48 PM
How do you get the trouble codes when the truck doesn't run? With the key? TIA
EinST Dec 12, 2011 5:31 PM
Buy or rent a scan tool or code reader and then plug it into the OBD data link port under the dash with key on?
Dirtiest Hoe I know Dec 12, 2011 6:06 PM
^ agree, or borrow a friends.
Throw a battery charger on the battery if the car is weak, which I imagine it is if it doesn't run / no return power from alternator.
chazwel Dec 13, 2011 6:28 AM
On some makes you can turn the key and get codes with blinking lights, maybe not this make. I killed and charged the battery once. Thanks Guys.
EinST Dec 13, 2011 11:14 AM
That was OBD I days, i.e., 1995 or older. Anyway, the CEL should be lit with key on, engine off. If yours won't start, the CEL is not really a good diagnostic aid.
chazwel Jan 24, 2012 12:18 PM
Bought a $20 scanning tool, will let you know the results.
