Washer fluid malfunction
I have a 2013 Suburban LTZ that I just bought. I noticed the message saying windshield washer fluid low so I put some in it. When I got back in the vehicle and started it, it automatically started spraying fluid out. Not full force like when you push the switch to spray fluid but just a steady stream. I’m assuming the switch is bad and is sending power to the pump constantly. Any suggestions on how to check/fix this issue? |
Well, if it were mine, I'd unplug the pump and see if the issue stops, which I can only assume it would unplugged :)
Then I'd see if there was 12v coming from the wiring going to the pump, when the truck is 'on', but you aren't pressing the switch. Which indicates it's getting power when it shouldn't. Then I'd unplug / remove the switch, and again check for power at the pump wiring. If it goes away, I'd highly suspect the switch as the issue.. Then I'd look up the part for the switch and replace it... Or, more likely, just buy the switch and swap it since you don't want to take it apart 2x. |
Originally Posted by Chuck1102
(Post 359424)
When I got back in the vehicle and started it, it automatically started spraying fluid out. Not full force like when you push the switch to spray fluid but just a steady stream. I’m assuming the switch is bad and is sending power to the pump constantly. |
Originally Posted by a55bruce
(Post 359453)
The BCM provide the signal that closes the relay for the pump. Does the washer provide full force when you push the wash button? If not you may have a bad relay or a bad ground for the pump. Pulling the FRT WASH fuse should stop the pump until you find the problem.
(Post 359686)
... The high beam headlights and the fog lights will come on sometimes when they shouldn't be on. They will be real dim but they will be on.
The door lock is probably a separate issue. Does the passenger door switch lock the door? Does the left rear door lock work at all? The same relay controls both back door locks, if one side works then the problem is in the wiring to (or inside) the doors. |
(Post 359697)
Sounds like your gremlin is probably a bad ground. The fog lights, headlight, & the washer pump share a common ground. Follow the black wire from any of these to where it attaches to ground, make sure the it has clean metal under the screw.
